Looking for good compact for gig photography?
Discussion in 'Photography Forums' started by heathen666, Feb 11, 2014.
  1. heathen666
    heathen666
    Jan 7, 2005
    2,462
    116
    Basingstoke
    +1,543
    I've been using a canon sx220 for gig photography for a while, with reasonable results. I like the level of zoom on it and knocking the iso up doesn't make the pics don't become too grainy.
    Question is, seeing as this camera is nearly 4 years old, there anything out there around the £300 - £400 mark that would be an upgrade. It'd need to be fairly small (fit into a hoodie or jacket pocket), reasonable in low light (I'm not expecting miracles here).
  2. Ugg10
    Ugg10
    Apr 17, 2009
    3,206
    +1,571
    The usual suspect at this price is the rx100 but this only has a 4x zoom. 14x zoom and large sensor (for low light photos) and large aperture are not usually found together. You may find that thebetter sensor with a smaller zoom can be cropped to match your longer zoom.
    So, when looking the things to look out for are -
    Sensor size 1/1.7, 2/3 or 1"
    Lens with max aperture of f2.8 or larger i.e. Smaller number like f2.0
    Then zoom, wifi, burst mode speed, panoramic, hdr etc. are down to preference.
    Snapsort.com is a good spec comoarison tool and have read of snerklers camera chooser sticky as well.
    Coolpix p7800 or older p7700 may be worth a look.
    Hope this helps get the ball rolling.
