Looking for good cheap multi-region upscaling DVD - Any suggestions
Discussion in 'Blu-ray & DVD Players & Recorders' started by lather30, Jun 15, 2009.
  1. lather30
    lather30
    Jun 4, 2009
    7
    3
    I'm currently on the look-out for a decent upscaling DVD player, but I also need one which has multi-region capability (or can easily be hacked to get it). It also needs to be fairly cheap (ideally less than £50), and if it is physically small as well, that would be great too - we don't really have space for a big box.
    So, can anyone suggest a machine which matches what I'm looking for?
    Thanks in advance...
  2. blaster9999
    blaster9999
    Aug 15, 2007
    1,310
    63
    +128
    I've just bought an tosh xde 500, the quality really impressed. Dead easy to unlock Picked it up with a year free lovefilm for 60 quid. I didn't "really need " another player but this was cheaper than paying for a years membership. :) That finished now so maybe you'LL pick them up cheaper There is a review on the forum Which If I remember correctly suggested the machine was better with ntsc than PAL:eek:
