Looking for Freeview with SVideo out?
Discussion in 'Freeview & YouView' started by devs, Jun 1, 2005.
  1. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Do you have a box that has this option? If so could you please let me know what one it is?
    Thanks,
    Devs. :smashin:
  2. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    The JVC TU-DB1 has an S-Video output.
  3. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Excellent Cheers Gary - how do you find the picture quality on that one mate?
  4. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    Well I would say it's very good, but I have JVC connections so I'm biased.
  5. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Good man does that mean your going to offer me one cheap? ;)
  6. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
    Best I can do is email you the latest software if you buy one I'm afraid.
    BTW - Latest version is 2.2.
  7. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    If you're after a good Freeview box with s-video output, you should definitely consider the Sony VTX-D800. Check out Sony's dedicated website and have a read of the manual, etc.
  8. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Excellent thanks for the link I wasn't 100% if this had svideo - I think its the one I'll go for...
    Cheers!
  9. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Hi sdc395, I've just downloaded the manual and it doesn't show the svideo output on the back? Are you sure it has one?
    Thx!
  10. devs
    devs
    Mar 23, 2004
    1,507
    38
    +18
    Scrap that question I now realise that it is svideo via the scart.
