Looking for discrete code AVR300
Discussion in 'Arcam Owners' Forum' started by Barend, Nov 4, 2004.
  1. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Hi all,
    I got all commands working fine on my PDA using NetRemote, the only one sadly lacking is the setup command, tou know the one you have to press for 5 secs and then release.
    Does it exist?
    Everytime the MENU pops up instead of the SETUP...
    BTW-
    Since I bought the unit I had no inclination to buy something else- my wife is starting to look at me in a funny way "What's wrong with him? No more cardboard boxes in the room!".
    This baby's sound is as gorgeous as in June when it arrived, my KEF speakers are almoust purring from joy :thumbsup: .
    Barend :)
  2. Hifi addict
    Hifi addict
    that is so unlike you :D guess this Arcam rules your house now.
    but you could check the arcam webpages as they updated the remote control code pages and it could be on that new page.
  3. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Sadly, there is no discrete for the setup code.
    My Home Theater Master MX-700 remote works, however, with holding the Menu button down for several seconds.
  4. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Is this a feature you would like added? I can see if the software team can do this. No promises but I will ask.
    Regards,
    Andrew
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I've never thought to ask for that, but could use it. You have my vote.
  6. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Thanks Dean,
    I know, the problem is really in my pda, it sends the code only when you RELEASE the button!
    I guess "normal" people won't need the Setup very often...
    barend
  7. Barend
    Barend
    Apr 12, 2004
    804
    +9
    Thanks Andy,
    Having a separate code for SETUP would be lovely!
    Barend
  8. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Also, is their a discrete code for switching between AM/FM??
  9. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there, could some please tell me where i find the arcam descrete codes from?
    thanks
    CaM
  10. Robin Francis
    Robin Francis
    All IR-codes for the AVR300 are in the manual (page 32-33). Switch between AM/FM is not stated in the manual but can be done on the CR80 remote. The tuner section uses code base 17, the same as the Arcam tuners. In the manual for the T61 (page 10) the IR-code for FM/AM toggle is 17-50. Maybe this will work.
  11. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    Hi there, my A32, A75+ & DV88+ don't seem to have there descrete codes listed.
    thanks
    CaM
  12. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Cheers again Robin. I didn't think of looking at the tuner manuals, just too excited at getting the AVR300 today :))
  13. Robin Francis
    Robin Francis
    The A32 uses the CR389 remote and so does the A80. Have a look at the A80 manual. The IR codes are listed there. All current Arcam DVD players use IR system code 25. I would assume that that is also the case with the DV88+. Have a look at the manual for the DV29/78/79. The IR codes are listed there.
  14. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Try...
    Tuner AM: 16-52
    Tuner FM: 16-53
    I'm pretty sure this is what I used. It's the same as the AVR200.
  15. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    ok, thanks for the info - I'll do some mx-700 programing tongiht :)
    thanks
    CaM
  16. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I also use a MX-700. Attached is the ccf with discretes I created to use with the MX Universal Browser. It includes the AM/FM discretes that aren't published in the manual.
  17. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Thanks Dwette, the AVR300 will be here within the hour, so I'll check it out then
  18. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Thanks Dwette, those discrete codes work for the AM/FM. I am still trying to find someone that know hows to alter the AVR300 to change the main zone IR system code from 16 to 19.
  19. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Glad that worked out for you.
    I would also like to know how to set zone 1 for code 19.
    Keep in mind, however, that switching from system code 16 to 19 will require recreating my ccf file from scratch.
  20. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Dwette, I have already built my Marantz RC5200 CCF with the system code to 19 before my AVR300 was delivered. So currently I have a fully programmed remote, with no way of changing the AVR300 :( Very frustrating. My own fault for trying to be too clever and thinking ahead :)
  21. parrydave
    parrydave
    Hi all,
    I'm looking at getting an mx-700 to control my kit, including an AVR300 and A85. I'd like to switch AVR300 to code 19 to avoid conflicts.
    1. Did anyone work out how to switch from 16 to 19 (need latest firmware?)
    2. Can the Mx-700 be programmed with code 19 discrete commands directly or would I have to get them into a .ccf first then import? If so, how do I do that? Presumably exactly the same way that Dwette built up his code 16 set?
    Just want to make sure it'll do what I want before buying.
    Many thanks & merry xmas
    Dave
