Looking for Decent (cheapish) Component Cables
Discussion in 'Cables & Switches' started by domtheone, Oct 19, 2005.
  1. domtheone
    domtheone
    Nov 23, 2004
    16,322
    Nottingham
    +5,172
    Just picked up a Pioneer 575 DVD player, not got component on my current tv but will be getting an LCD soon (within weeks hopefully).
    Want to pick a set of component cables for when this happens.
    I'm also planning on taking my DVD player to a few shops to try out a few panels and the cables will probably come in handy then (if the store cannot provide a set for testing :rolleyes: )
    Budget.....hmmm, well, can i get a half decent set for £20 odd.....
    Only need be a metre length or so
    TIA
  2. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    search on pcworld website for 'Component' there are a set of £25 Belkin cables which can be had for less than £8 when you reserve online and pick up in store! ;)
  3. nhart
    nhart
    Hi dometheone.
    Check out the Posts from Mark Grant on this Forum (link below)
    www.avforums.com/forums/showthread.php?t=104551
    He'll knock you up a set of Belden Vidoeflex Snake Component leads for reasonable sums. Apparently, they are the dogs dangly bits.
    N.
  4. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,983
    The Borders
    +3,592
    domtheone
    I'd normally advise you to consider a set of VanDamme 'Component' cables - though they are slightly over your indicated budget.
    Look to someone like TV Cables (who have a PAID FOR BANNER ADD on here - why do folk insist on linking to sites that make no contribution [financial or otherwise] to the AVForums) for a set of low cost YUV cables.
    If your going to be using these cables as part of your mobile 'test' system ensure you get ones with robust connectors on otherwise you may find you loose an RCA plug at some point on your travels.
    Best regards
    Joe
  6. domtheone
    domtheone
    Nov 23, 2004
    16,322
    Nottingham
    +5,172
    Thanks for the recommendations guys.
