looking for cheap divx-xvid dvd player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by edmond, Oct 21, 2005.
  1. edmond
    edmond
    Sep 9, 2004
    243
    28
    +32
    i know it has been asked a number of times
    i have been using my ps2 to play dixv - xvid files
    was hoping to buy a cheap dvd player any ideas?
  2. ged1a
    ged1a
    Mar 22, 2003
    95
    try ebay ..layfayette 969 going for £42 ...£12 postage
  3. n83a
    n83a
    Aug 7, 2005
    46
    hi you've been using a ps2 to play divxs! could you tell me how this is possible?
    cheers, n83a
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    yes I would be very intrested as well :)
  5. lees10
    lees10
    Jun 30, 2005
    26
    3
    sunderland
    as far as i know, you need extra erm, "hardware" and some software to play divx on ps2 (google search for "ps2reality").
    in my experience, the playback quality of divx on ps2 isn't great.
  6. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    You need a way to play copied discs e.g modchip, swap disc etc. Then get PS2Reality media player. Its free. You then boot that, swap to your divx disc and select which files to play. Or if you have a network adapter you can stream the files from your pc if you setup a network.
    It has some limitiations e.g you need a way to boot PS2Reality. It more limited in the codecs it supports compared to a mediatek based dvd player. Its bitrate limit is lower than a dvd divx player e.g you get jerky or slow playback.
    Overall its pretty neat but a dvd divx player is a much better solution overall.
  7. n83a
    n83a
    Aug 7, 2005
    46
    cheers nx3. will google it
  8. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
  9. edmond
    edmond
    Sep 9, 2004
    243
    28
    +32
    yeah thats right
    you need to download PS2Reality media player.
    and you PS2 needs to be chipped.
    You can either burn the PS2Reality media player files to a CD and load this then insert the divx file,
    of you can load the PS2Reality media player onto a memory card and load from there.
    The easiest way i have found is to burn the PS2Reality media player along with the divx files onto a DVD using Nero under the DVD-ROM (UDF-ISO)
    i have not had any problems with and Dix files i have used.
    however the last DVD i burnt and tried to play the sound was jerky.
    i think this may have been down to the DVD media i used.
    Hence this is why i am thinking of getting a DVD player which can play Divx
  10. themighty
    themighty
    Oct 24, 2005
    156
    +3
    Just tried this pS2 thing after reading this thread, and it worked fantastically! Just wondering how you can load the Media Player onto a memory card. As for Dvix players, I hear KISS players are very good! Does anyone know much on http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=65001
    £90, and will stream the files straight from your computer from a wireless internet connection!
  11. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    Kiss....oh boy....do a search on this forum. I've upgrade from Kiss to LG / Targa/ Pioneer for various members of my family. Mediatek based players imo are far superior.
