Looking for best speaker choice for mini hifi and computer
Discussion in 'AV Receivers & Amplifiers' started by ciber, Jan 16, 2004.
  1. ciber
    ciber
    I have an ONKYO mini amplifier around 20W, try to get a Hi-FI bookshelf speaker for computer music and stereo CD music. Since I am using computer when listening the music,
    The distance is less than 3 feet from speaker to my ears.
    Three Choice,
    Big Standard bookshelf, i.e, KEF Q1, Tannoy MX2, AE300
    Mid size bookshelf, i.e, Castle Richmond, AE300C
    Small size, i.e. such as AE301,
    which one is the best for close listening and small amplifier??
    AE-300 Specifications
    HF unit 25mm neodymium tweeter , 180mm mid/bass driver with 32mm coil, die-cast chassis
    Power Handling 150W max
    Frequency response +/-6db 40Hz to 23kHz
    Sensitivity 87.5 db/W
    Impedance 8 ohms
    AE-300c Specifications
    HF unit 25mm neodymium tweeter , 150mm mid/bass driver with 32mm coil, die-cast chassis
    Power Handling 100W max
    Frequency response +/-6db 45Hz to 23kHz
    Sensitivity 88.5 db/W
    Impedance 8 ohms
    AE-301 Specifications
    HF unit 19mm neodymium tweeter , 110mm mid/bass driver with 25mm coil, die-cast chassis
    Power Handling 70W max
    Frequency response +/-6db 60Hz to 23kHz
    Impedance 8 ohms
