Greeny155
Hi, my first post. Looking for some help/advice. My mum(90) is registered severely partially blind. She has just returned home after 2 months in hospital & a stay in a Rehab unit. As well as visual difficulty she is now experiencing memory problems. Even using a simple zapper remote (on/off, sound & channel buttons only) is proving very difficult as she forgets which buttons to use.
Her TV (not a SMART one) is connected to a Virgin media STB. She had Freeview but had to switch as the signal strength was weak at times, other times OK, advised by aerial guy that large trees close by were the main problem. At a loss to know what to do for the best. Any solution has to be simple to operate and failsafe. Searching for ideas. I've thought about:-
1) is there anyway to improve the Freeview signal strength (that would eliminate the use of the STB) and one less button on her zapper to bother about.
2) Is the voice recognition technology mature and user friendly (very user) enough to offer a viable solution? I've read about using Alexa & Harmony but have concluded there's still a way to go to make it a "Janet & John / easy to use " type solution.
3) is there anything available to pre-programme channels for, let's say, the forthcoming week, so that the TV(STB) automatically switches itself. Recordings wouldn't work as that would be too difficult.
Having spoken to the technical people at RNIB who suggested I try posting something on this forum.
Other than this post, I'm now at a complete loss as to what to do next, short of, leaving the TV switched on permanently with the sound on and on a station that provides the best possible variety of suitable programmes.
Any help/advice would be much appreciated.
Thanks in advance.
Thanks in advance.
