Looking for an Upgrade
Discussion in 'AV Receivers & Amplifiers' started by zahidhafeez, Aug 30, 2013.
  1. zahidhafeez
    zahidhafeez
    Nov 27, 2006
    7
    4
    Hello Fellow Members.
    I am considering to upgrade my old AV Receiver (Denon AVR-3805). I have Klipsch Speakers connected to it which I love and only considering to upgrade the AV Receiver.
    I am at present considering Denon AVR-X4000 however open to suggestions. I look forward hearing your views and suggestions in this regard.
    Thanks and Regards,
    Zahid Hafeez
  2. dante01
    dante01
    Mar 5, 2009
    45,613
    +10,856
    You can pick up a Yamaha RXA2020 for less and I'd consider this to be a better amp. You can also get an Arcam AVR400 for about £1K.
    If you are going to spend the extra cash then I'd suggest you consider the Marantz SR7008 rather than the Denon AVRX4000. The Marantz's features are more conducive with what you'd expect to get with an AV receiver costing over £1K i.e. it has 9 channels of amplification as opposed to the X4000's 7. I'd have to say that the X4000 is overpriced because of this.
  3. nenito2k
    nenito2k
    Aug 13, 2008
    1,384
    +118
    do you really need to waste 1000£ for an AVR :facepalm:
    with internet prices are going down each week...and for 500£ there are plenty of very good models...just read reviews mate
  4. wezzywebb
    wezzywebb
    Feb 12, 2004
    7,953
    2
    fishburn
    +7,564
    Hi take a look at the Pioneer SC2022,available for £399 via Peter Tyson ebay outlet
