Hi all,
I need a little advice on choosing an amp under £400. I want to get away from using the AVR for music but won't be able to listen too often so don't want to spend too much money.
It will be driving Q3050i speakers, but they may change to MA Silver 300 so they match my MA centre. Sub out via rca would be handy I guess, but I'm not sure if I would have control over the bass as the subs are set up for HT use and don't have high level inputs.
Source will be a CDP and I don't really stream anything.
So far I've seen:
Rotel A11 Tribute £349
NAD C328 £349
Denon PMA-600ne £359
Any advice on those or any other amps I should consider?
Cheers!
So far I've seen:
NAD C328 £349
Cheers!
