firetrap
Established Member
Hi Guys,
I've had a 5.1 setup in my living room for the best part of 20 years. It's a bit of a mixture of speaker brands and was done on a low budget at the time. My trusty Sony STR-DB940 AVR finally gave up the ghost about a month ago and until I replace it i'm living with the audio from the TV speakers.
My initial reaction was to go out and buy the latest Sony amp in a similar price range to replace it (STRDN1080). However, I decided to do a bit more research on here as there didn't seem any point in spending £400 on a new AVR if my current budget speakers were going to let it down. I know, for instance, that my sub is next to useless and needs replacing.
My current set-up is as follows (don't laugh too much
TV : Sony KD49X8505B (4K)
AVR : Sony STR-DB940
Front L/R Speakers : Eltax Symphony 4.2 (wall mounted) Eltax Symphony 4.2 Floorstanding Speakers user reviews : 3.6 out of 5 - 5 reviews - audioreview.com
Front Centre Speaker : Celestion F35C Celestion F35C - Manual - Center Channel Loudspeaker - HiFi Engine
Rear L/R Speakers : Mission 70DS
Active Sub : Acoustic Solutions SA750 (probably from Argos!)
All speakers are wall mounted just above the height of the TV (approx 1.5m). The room measures 20ft x 11ft and I've attached a layout of the room below.
I mainly stream video from my Virgin V6 box (Netflix/Amazon), but also have a PS4pro and PC connected via ethernet to a streaming box.
I'm thinking of trying to keep to a budget of around £1000. I'm swaying towards getting a Denon AVR2500H or Sony STRDN1080 and a BK sub. I'm not bothered at this point about Atmos, so hoping that the rear Mission speakers will suffice.
I'm not so sure about the front speakers as I realise they should really match, which they don't at present.
I hope i've provided enough info. Any advice or suggestions to revive my system and improve it at the same time would be appreciated.
Si.
Si.
