Looking for advice on processor upgrade
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by BBD, Jul 8, 2003.
  1. BBD
    BBD
    Mar 13, 2001
    430
    Lutterworth
    +3
    I recently bought a pair of Meridian M66's and a M66C. Until last week I was using this set-up with a HK AVR5000. I am currently saving up for a secondhand processor (Tag/Lexicon/Meridian) and decided to sell the HK now before it depreciated too much. I am currently using a HTPC to drive the M66's directly from a Revo soundcard. I now have the opportunity to buy a Rotel RSP976 processor for just under £400. Is this a good price and should I use the money from the HK sale to buy it as a short term solution or stick with the Revo until I can afford the Tag/Lexicon/Meridian processor?
  2. GreenEagle
    GreenEagle
    Jan 16, 2003
    Maidenhead
    Wait until u can afford the Tag/Lexicon or Meridian
  3. NicolasB
    NicolasB
    Oct 3, 2002
    5,881
    Emily's Shop
    +566
    Depends: how long is it going to take you to save up £1500-£1800?
  4. BBD
    BBD
    Mar 13, 2001
    430
    Lutterworth
    +3
    Good question I have a Sony G70 projector in need of two tubes (£1250) aswell. I guess what I'm actually asking is, is the Rotel a good buy price wise and good enough to live with for at least a couple of years? This would allow me to have the Sony retubed first. If its not a good price I can stick with what I've got until I saved up enough for the Tag/Lexicon or Meridian and retube the Sony at a later date. (Or should I just buy lots of lottery tickets!)
  5. NicolasB
    NicolasB
    Oct 3, 2002
    5,881
    Emily's Shop
    +566
    Yes.
    Only you can answer that one - by listening to it.
  6. GreenEagle
    GreenEagle
    Jan 16, 2003
    Maidenhead
    BTW Nicolas have u received your Bryston Sp1.7 yet?
    When you get pleas write a review because am looking to upgrade my SP1 at the end of the year.
    cheers
  7. NicolasB
    NicolasB
    Oct 3, 2002
    5,881
    Emily's Shop
    +566
    No, I haven't! :(:mad::eek::rolleyes::nono::thumbsdow:suicide::(
    They emailed me yesterday and said another 7 to 10 days. Probably.
    If you do a search you'll find several previous postings by me on the subject of the SP1.7.
  8. Mr 928
    Mr 928
    BBD,
    Save the money and buy a Lexicon - coupled with a pair of good quality amps (5 channel & a 2 channel) you can't go wrong. Plus with Lexicon you've got LOGIC 7 - It's pretty much all I use. 5.1 Logic 7 / DTS Logic 7 - awesome!! As long as you've got 7.1 speakers :D
  9. BBD
    BBD
    Mar 13, 2001
    430
    Lutterworth
    +3
    Just to give an update. I managed to knock him down to £335 on the Rotel RSP976 and after extended listening of the M-Audio card I decided I just couldn't live with it for a year. It wasn't possible to demo the Rotel with my speakers but I thought at this price I'd take a chance. After a quick set-up and listening session I'm glad I bought it. A lot better than my HK AVR5000 and as long I can avoid listening to any Meridain/Lexicon/Tag kit until I can afford one I'll now be happy to wait.
    Thanks for the advice and comments.
