Looking for a way to hide a 32 inch lcd
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by JayList, Nov 5, 2005.
  1. JayList
    JayList
    Got an RD50.
    Tried to hook up the Sharp 32 inch lcd and the missus said no way.
    So I need a way to disguise it.
    Either cabinets, plasma lift, or ??
    I might get a custom cabinet, with doors to hide the lcd. The plasma lifts start at around £1400.
    seen this picture life, from £1000.
    http://www.cyberselect.co.uk/product/904
    Anyone got any suggestions?
  2. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,485
    Essex
    +1,101
  3. JayList
    JayList
    I've seen the mirror tv frames on some website. Didn't say how much they were though , pricey I bet.
    But it is a possibility. The shame is we might be moving in 6 months time so don't want to alter the house in anyway.
    What sort of cost is it for a custom cabinet?
    EDIT
    I know the price can vary buy say If I wanted to hide my 32 inch lcd in a cabinet say 120cm high. Woukd £600 be enough?
  4. JayList
    JayList
    Hey.
    You can get this http://www.actuators-electric.co.uk/picts/pdf_7.pdf
    This is used for plasma lifts by itself, looks good, or can be used to hide stuff.
    Mmm, this may be the fella for me.
    Just need a cabinet to hide it in now, or a radiator cover.
  5. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    How many years bad luck would breaking one of those add up to???
    Nice idea though.
  6. JayList
    JayList
    Found a list of prices for differant plasma lifts.
    inca plasma lift for 32 inch screens is
    http://www.inca-tvlifts.com/index.html
    Inca 900814-32 32" Plasma Lift £1405.1
    Inca 900813-110AI Controller / PSU £189.1Inca 900820 RF Remote Control £237.71
    Prices do not include VAT or UK Freight charges
    Lifteronic plasma lift
    PRODUCT CODE DESCRIPTION TOTAL WIDTH MAX. TV WIDTH TOTAL DEPTH TOTAL HEIGHT MAX. RUN RRP PRICE £
    MM MM MM MM MM
    PTV0814S-32 PLASMA/LCD 32" 988 932 143 838 668 1,753.18
    PRODUCT CODE DESCRIPTION PRICE £
    PS-110-220 POWER SUPPLY 237.99
    IN 110V/220V OUT 24V
    IR-REMOTE INFRARED REMOTE CONTROL 46.64
    http://www.lifetronic.it/tvlift.htm
    And saving the best till last
    Note the others will cost about £1500 for the system including IR..
    Multlift system (Direct from the manufacturer)
    For a single unit with IR Remote control £453.00 net (around £540 gross) each.
    Delivery 2-3 weeks.
    This costs about £1000 from the retailer I contacted.
    So I can buy a raditaor cover, and mount this in relativley easily. I am looking to see how you would attach the LCD to it.
  7. clarkesville
    clarkesville
    Apr 14, 2005
    101
    19
    Birmingham
    Try the guy`s at http://www.intekvcf.co.uk/ they do all sorts of bespoke stuff
    I`m having an av cabinet made at the moment for £350 to mach our existing furniture :smashin:
  8. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,485
    Essex
    +1,101
    i remember seening a clip on the net about them mirror tv's. around 2k i think it was
    as to the cabinet it depends what you wanted it made from. ?
    also the width and depth of the unit too.
    shame about u moving too. coz depending on the wall your tv is in front of,
    i dunno the size of ur room but.. you could dry line that one wall.... and make the stud frame to suit a lcd.. extra support where needed etc. so its hidden inside the wall.
    but it all depends on the room width and length... and other facters...
  9. vincer
    vincer
    Nov 25, 2005
    22
    Do you have contact details for manufacturer or link to site?
  10. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    why she say 'no way'?
    surley its better looking than your old crt??
    put your foot down :lesson:
  11. JayList
    JayList
    Yes, I'll dig out the info and post here.
    J
  12. JayList
    JayList
    Well she did let me fill the lounge with the RD50! :smashin: I am working on the LCD , once we move house it will have a permanent place in the new lounge.
