UncookedTaco
Established Member
Which external devices do you plan to connect to the TV?
- PS4/PS5
What content will you watch on the TV?
- Will be used 80% for gaming, the other 20% for watching movies sometimes.
Will you use internal or external apps or tuners for the following? If external, via which device?
- Not sure which device or if external or internal. Currently I'm not planning touse apps or tuners.
Situational questions:
Please rearrange the following, in descending importance:
More information:
I've been researching a bit since last year, and this TV (Sony BRAVIA KD55XH9505BU) has been recommended often by both Dodgexander and other users. My only use for the TV would be gaming. I do care about HDR but don't care about HDMI 2.1 and 120hz. I'll be fine with 60hz. All I want is something that is long lasting and reliable, and if there is a better TV that's cheaper than this one, then I would be glad to take recommendations.
I want to look at the situation from a usage/price perspective. Most people here are justified in buying a more expensive TV because they will actually use it for things like movies/shows and streaming content alongside gaming. I also won't have much time to game unless it's the weekend, so the TV won't be getting a lot of use per week (Like I said it's only for gaming, nothing else). My brother will probably be playing a bit of Fortnite but mostly the TV won't be used much. My previous 1080p Samsung TV (Samsung UA40H5303AK) does not work anymore so this will basically be the main TV. The only reason I am hesitant to purchase the TV is due to the fact that I feel I won't be getting my moneys worth as I wouldn't use it often. Due to this fact I feel as though it will be better to purchase a cheaper TV but I think those have worse build quality so I would just end up spending more in the long run.
Lastly, I would like it to have good upscaling. What I mean by this is that my PS4s maximum resolution is 1080p, so I would need it to look decent on the 4K display.
- PS4/PS5
- What TV are you currently using and what are expecting to see upgrading to a new TV?
- Are you a tweaker or set and forget kind of person?
- What is your viewing distance?
- If you place yourself in the position of your TV facing towards where you watch, at what angle from the centre is each integral seating position? (Tip, use a protractor to measure angles).
- When will you use the TV and what kind of lighting will be in your room? Some examples:
- Value
- Cost
- Sound
- HDR Picture quality
- SDR Picture quality
- Picture accuracy out of the box
- Blacks
- Viewing angles
- Shadow detail
- Smart TV ease of use
- Smart TV app selection
- Motion stutter
- Colour banding
- Bad screen uniformity, Dirty Screen Effect, Clouding, Light Bleed, Blooming, Vignetting, Haloing
- Motion Blur
- Loss of detail in dark areas or crushed blacks.
- Reflective screens
- Slow smart TV
- Raised blacks
More information:
