Quantcast
Looking for a TV cabinet which is 150cm wide and has legs which are 6cm but not finding anything, any suggestions?
So i need to put the tv cabinet over a piece of marble in front of the fireplace.
I am looking for a cabinet which is 150cm wide and has four supporting legs which are 6cm to give the clearance over the piece of marble. The cabinet also needs to be able to take 55kg of weight.
Really struggling to find anything, anyone know of anything?
Found this but the weight it supports is not good enough TV Cabinet Walnut Vaughn TV Stand 1823096COM by Dorel
Kend3591
John Lewis have a selection of media units on legs
StefanBFC
This is 160mm long, has short legs, you could cut the legs down to what you need them at.
