looking for a TV 32" or more with a thin bezel
Discussion in 'TVs' started by music, Apr 25, 2005.
  1. music
    music
    Mar 25, 2005
    518
    +14
    now to upgrade TV, - but want to be able to put it inside a fireplace (where current 28" model sits), therefore I want the thinnest bezel edging possible to get in the maximum screen size.
    Often the bulk at the sides and bottom of the screen is all about speakers - which is annoying because I use my own speakers anyway...
    But I reckon I could get 32/34" in there, I doubt 36", but .......
    asny recommendations of where to start looking gratefully appreciated.
  2. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Check out the zp range by toshiba.Very thin surround.Good picture as well.
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Yes, I recommend the Toshiba 32ZP48 for your application. Regards, yt.
  4. music
    music
    Mar 25, 2005
    518
    +14
    okay I will have a look at that and see. THanks
