Looking for a sub better than MA AW12
Discussion in 'Subwoofers' started by Baggins Shire, Sep 7, 2012.
  1. Baggins Shire
    Baggins Shire
    Sep 7, 2012
    34
    +7
    Thinking about purchasing the Monitor Audio Apex package but I was a bit dissappointed with the subwoofer when I heard it at a recent...was hoping for some more ooomph from it.
    While it sound fine for the big explosions etc I wanted to litterally "feel" them, which I didn't think this sub did.
    Is there any sub up to £1500 that you can recommend that is better than this sub?
    Bilbo
  2. Faffer
    Faffer
    Apr 29, 2008
    670
    43
    +153
    Well I have the Apex kit and a Monolith .. you can feel it but its not going to be all that much .. but adding a Earthquake Quake 10b to your sofa and you then have all the feeling you need and a sound to go with it.
    in total spending under your £1500 and also getting more than just a sub .. the Quake work down to 5hz so you get them extra low feeling
    Richard
  3. Razorclam
    Razorclam
    May 3, 2011
    2,354
    116
    +690
    If I had that budget (which I don't) and those speakers (which I do) I wouldn't hesitate to buy myself the new SVS SB-13 Ultra.
    But that's just me.
  4. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    6,086
    2
    2
    Bromsgrove
    +613
    Any of the SVS range would be worth a look (read the reviews of the Cylinders on here)
    You're not far shy of the baby M&K.
    £1500 is nudging toward second hand Velodyne DD, B&W DB1, Paradigm Sub12 etc - some real high end stuff.
