Looking for a stand for a 42 inch plasma
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by AkhilStyle, Mar 15, 2005.
  1. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    Hello
    Just ordered my new Panasonic 42. Looking for a stand. I saw the Alphason adp396s at John Lewis - £450 seems a lot though
    I like the "double" stands - if you know what I mean. That are the whole length of the tv, and can fix two devices on one shelf next to each other. I.e. the wider ones.
    Any good suggestions? How much am I looking to spend?
    Thanks!
  2. processor
    processor
    Hi AkhilStyle,
    If you want to mount your screen on a column (as with the ADP3/96S you mention) then you might like the Alphason AG94/2S, for £300 from here http://www.shopatdigital.co.uk/acatalog/AG942S.html
    Alternatively, if you buy a pedestal stand for the Panny you could put it on an Alphason AD3/105, which has plenty of shelf space for all your kit, and comes in at around £280 from http://www.tvandvideodirect.com/product.php?xProd=105
    If, at the end of the day, you prefer the ADP3/96S that you have already seen, then you can save £70 by buying it here http://www.be-direct.co.uk/productDetails.asp?id=16478
    Obviously, if you shop around, you may find all of them cheaper, but these seem quite good prices
    Good luck with the quest!
  3. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,574
    Woking, Surrey
    +44
    See my post HERE
    :thumbsup:
  4. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    Amazing price - gonna ring currys in the morning ;)
  5. thekingbeyond
    thekingbeyond
    May 24, 2004
    6,294
    oxfordshire
    +408
    Do you think the KM1180 would take the 45inch samsung dlp tv
  6. frank-g
    frank-g
    Feb 13, 2005
    112
    16
    Isle of Dogs
    I purchased a KM1050 from Currys on thursday for £99.99. I think it is a little wider than the 1180 but looks very similar (Currys sales guy said he `thinks` the 1050 has thicker glass but had no 1180s in stock to check).
    I have a panny 42-PWD7 and there is room to spare either side.
    Oh, the stand was on display with old price of £129 so if you see one at that price, get them to check on their system.
  7. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    I ordered the KM1050 on the Currys website - £60 + £20 for delivery
  8. frank-g
    frank-g
    Feb 13, 2005
    112
    16
    Isle of Dogs
    Uhmmmm. Thought I had been hit by the 'great buy it then they drop the price' syndrome. Just had a look at Currys site and they are still showing the KM1050 at £99.99 + £4.99 delivery. Was It the KM1050 or 1180?
    Anyway, if it is the 1050 that's a real bargain on an already great buy. I am certainly glad I didn't buy an Alphason stand and the saving can go on a component board!
  9. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    Sorry was the 1180
    Got the code wrong - still a very good price
  10. Gedii
    Gedii
    Will the 1180 hold a 37" PW7 (I think they are about 25Kg)
  11. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    Yes - I have my Samsung 42 on their atm
  12. phil_mo
    phil_mo
    I think all Currys outlets are now out of these stands (KM-1180) as I had to ring round about 25 branches and finally had to travel 120 miles to get one.
    They had two left so I bought both as I thought a friend of mine may want one but he had already splashed out on an Alphason version the day before DOH! :D
    MOD COMMENT Link removed
    [​IMG]
  13. creambun
    creambun
    Mar 29, 2005
    251
    gloucester
    let me know what you want for other stand :)
  14. phil_mo
    phil_mo
    If you fancy having a bid just search for the phrase "PLASMA / LCD AV / HOME CINEMA STAND" on eBay! ;)
  15. creambun
    creambun
    Mar 29, 2005
    251
    gloucester
    just got the stand from currys took the print out with me from the forum
    they had a look found 4 on system great price £59.99 good quailty too
    gloucester branch have a few left but hurry :thumbsup:
  16. creative-av
    creative-av
    Aug 30, 2003
    1,093
    48
    +56
    All,
    Curry's in Guildford had 13 instock after I purchased my 2 :clap:
    I think they were going to use a few more as display units so be quick!
    Steve
  17. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,574
    Woking, Surrey
    +44
    I bet the Woking store still has some too
  18. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,082
    Do they do transfers between stores?
  19. creative-av
    creative-av
    Aug 30, 2003
    1,093
    48
    +56
    The various stores I called said that they wouldn't transfer stock. You can get them to reserve the stand but only for that day.
  20. mista
    mista
    Oct 12, 2004
    506
    Cambridge
    +17
    Can someone tell me how wide the 1180 is - Thanks
  21. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,574
    Woking, Surrey
    +44
    1180mm
  22. phil_mo
    phil_mo
    118cm ;)
  23. logic3
    logic3
    currys have now got the km-1050 back in stock not the 1180 tho!! ive just got it from aintree branch liverpool i paid £129 am going to print this thread and show them the price paid online etc see what they have to say?? the stand now comes with a cable hider (hence the price hike??)will post when i find out you can see a pic -currys-tv stands -other catagories!! as a hi fi stand??(well hidden again) looks the bussiness tho also glad i didnt get the alphason at this price, glass is very thick weighs a ton
  24. mista
    mista
    Oct 12, 2004
    506
    Cambridge
    +17
    Got the 1180 for £60 in Belfast - Originally sold me the 1050 as a 1180 but I went back in and told them that it was not wide enough so they had one on display whuch they swapped with me
    Set it up last night great table at a great price
