Looking for a reasonably priced HDD MP3 player
Discussion in 'Headphones, Earphones & Portable Music' started by RMCF, Aug 3, 2005.
  1. RMCF
    RMCF
    Aug 24, 2000
    7,449
    +746
  2. HMHB
    HMHB
    Nov 11, 2001
    26,846
    Nottinghamshire
    +5,619
    I've not seen any reviews about it, but in my experience you tend to get what you paid for and are probably better off spending a bit more with one of the better known makes. It also makes it easier to get help from others on these forums if you have a player that a lot of other people are using :)
  3. johann1979
    johann1979
    Feb 18, 2005
    857
    19
    London
    I agree, in my experience and with DAPs being so fiddly and flimsy (Sony HD5), we spend more than enough time getting though the problems of the well known brands such as Apple, Sony and Creative that personally I would not even dream of considering to give a lesser known brand a go...
  4. jiwonuk
    jiwonuk
    if your looking for good priced hdd mp3, you should go for branded ones because all the hdd players have battery integrated and most times more unknown the player, the battery will be poor. and there is nothing more annoying than short battery life (well...in my case). i think rio carbon is a good player for the price. its the labs winner of group test on pc pro few months back. if you look up on currys or dixons online, its on web special right now.
