Looking for a nice stand
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by iainkane, Jan 21, 2008.
  1. iainkane
    iainkane
    Nov 1, 2007
    52
    Hope you can help...
    I am looking for a new AV stand for my new TV and AV system. The requirements are basically
    Holds a 50" TV
    Sky HD
    PS3
    AV Receiver
    Centre speaker
    Inbuilt cable tidy would be great
    Thinking black and I am open to glass or other materials. It is going in our new fancy open plan flat and basically has to pass the GF looks test, thinking pretty modern.
    Might be easier if anyone can suggest brands or shops that could help. Thanks in advance
    Iain
  2. Keri
    Keri
    Sep 17, 2002
    Tamworth, Staffs
    +6
  3. Phil37
    Phil37
    Dec 27, 2007
    112
    S.WALES
    +5
    iainkane,
    I was in the same position as you,I payed a lot for my 50inch TV and didn't want a crap stand letting it down.
    The Meliconi Flat Vision Star 200 Black is not cheap £309,but I have no regrets.
    Phil
  4. belfastchris23
    belfastchris23
  5. eric pisch
    eric pisch
    Dec 28, 2006
    7,501
    +754
    Not easy
    I just changed one of these
    http://www.standland.co.uk/zingt5bk.htm
    for this
    http://www.ebuyer.com/product/131764
    whilst they look the same they are not, the alphason is rated to 100kgs (much thicker glass, nb it weights 40kgs) is much higher quality in the flesh but more importantly has taller shelves which allows good air flow around an amp and also takes a 185mm centre speaker (which alot seam to be), i had trouble finding traditional style centre's that would fit the cheaper version
    better pics here (note centre on clear one)
    http://www.alphasondesigns.com/products.asp?ProductID=24&CatID=9
  6. iainkane
    iainkane
    Nov 1, 2007
    52
    Thanks for this mate, although I saw a rather nice cantilever one on another thread on here.
  7. PoisonJam
    PoisonJam
    Jul 11, 2005
    1,937
    3
    Central Scotland
    +153
    Have a look at the link in my sig and see if you like that one. I believe it holds up to 60".
  8. Nikko2
    Nikko2
    Nov 14, 2006
    +9
    I have a stand for sale in the trading area that sounds like it would meet all your needs.
  9. iainkane
    iainkane
    Nov 1, 2007
    52
    Ho PoisonJam
    Thats the one I had seen on one of the threads, would you recommend it?
    It looks the piece and is exactly what I am looking for. I've got my TV yet, so if they ain't back till end of Feb thats probably the perfect time for me, its open at the side to give my PS3 space to "breathe".
    Iain
  10. PoisonJam
    PoisonJam
    Jul 11, 2005
    1,937
    3
    Central Scotland
    +153
    There was a thread about it that you may have read and I have a few issues with mine. You can read my verdict here
  11. makemedie
    makemedie
    Jan 5, 2008
    5
    [​IMG]
    Modern? Check.
    Looks Good? Check.
    Save Space in flat? Check.
  12. Rich_n_Em
    Rich_n_Em
    Jan 10, 2008
    100
    +4
    I really like that full size one, been trying to find one like that with the two shelves, I can't seem to find one other than the Dwell single shelf...
    Can anyone find one like the above in the Uk?
  13. makemedie
    makemedie
    Jan 5, 2008
    5
  14. PoisonJam
    PoisonJam
    Jul 11, 2005
    1,937
    3
    Central Scotland
    +153
    Which one is that? :confused:
    Have a look at the ones on the right: here
  15. Rich_n_Em
    Rich_n_Em
    Jan 10, 2008
    100
    +4
    Euroway is in Texas - don't fancy having it shipped from there!
    Thanks PoisonJam, those look pretty nice...
  16. iainkane
    iainkane
    Nov 1, 2007
    52
    hi guys thanks a million for some of the input, I think that big all in one stand would be fab, shame about the america thing need to see what can be done. Although there is a stanner in that choices link above, oh decisions decisions...
    any other ideas would be hugely appreciated.
  17. Theowl
    Theowl
    Jul 31, 2006
    30
    Wrexham
    In the interests of balance - The alphason glass is not 'much thicker' they both use a 10mm top shelf. The weight of the GT5 is also 40Kg! I can not see a quality difference , I have dealt with both products. To be fair I think the plastic cable management on the GT5 is a bit tacky, but equally so do I think the tube cable tidy on the Alphason is. Take your point on them having different shelf spacings, horses for courses I guess.
  18. acehole008
    acehole008
    May 23, 2005
    46
    See this stand - I have bought this and has plenty of room for amps, centres and 60" plus plasmas. No cable tidy though. Will post a picture when set up.
  19. MCHardmanUK
    MCHardmanUK
    Feb 20, 2008
    127
    +5
