Question Looking for a monitor for gaming
Discussion in 'PC Gaming & Rigs' started by Maxlaps, Oct 8, 2017.
  1. Maxlaps
    Maxlaps
    Oct 8, 2017
    2
    Canadian living in Japan
    Hi guys,
    I am looking for a gaming monitor. Computer is only used for gaming on Battlefield 1 & 4, GTA5, PUBG, DayZ and starcraft.
    Here is my computer specs:
    Case: Phantek EVOLV
    Case Fans: ORIGIN PC High-Performance Ultra Silent Fans
    Power Supply: 650 Watt Tough Power 80+Gold
    Motherboard: ASUS STRIX Z270G
    System Cooling: ORIGIN FROSTBYTE 240 Sealed Liquid Cooling System for 1151 Socket
    Processors: Intel Core i7 7700 Quad-Core 3.6GHz (4.2GHz TurboBoost)
    ORIGIN Professional Processor Overclocking: ORIGIN PC Professional Processor Overclocking
    Thermal Compound: GELID GC-Extreme CPU Application
    Graphic Cards: Single 8GB NVIDIA GTX 1080
    ORIGIN Professional Graphics Card Overclocking: ORIGIN PC Professional Graphics Card Overclocking
    Memory: 32GB Corsair Dominator Platinum 3000MHz (2 X 16GB)
    Hard Drive One (Operating System Drive #1): 250GB Samsung 850 Evo Series
    Hard Drive Two: 1TB ORIGIN PC Approved Hard Drive
    Here are the monitors (all 1440p) that I have found, which one would be the best (if you have other recommendation, please share):
    -Asus PG PG278QR 27-Inch Screen
    --BenQ XL2730
    -Dell S2716DG 27-Inch Screen LCD
    -AOC AG271QG 27-Inch 165 Hz IPS Display
    -Asus Rog Swift PG279Q 27"
    -Acer Predator XB271HU Abmiprz 27"
    Thank you
  2. messenger
    messenger
    Mar 28, 2006
    1,255
    Southend-on-Sea
    +204
    I have this 'Acer Predator XB271HU Abmiprz 27' and cant recommend it enough. Colours are fantastic, brightness is so bright it has to be turned down to about 60%. The controls are pretty good once you get used to what each button does and 144hz is great, also it can be overclocked to 165hz if that's your thing.
    Overall PQ is brilliant especially @ 1440p, Input lag is not noticeable (4ms). The stand is really really solid and there is no screen shake when thrashing your keyboard on the same desk.
    Let us know what your opt for, good luck :thumbsup:
  3. Maxlaps
    Maxlaps
    Oct 8, 2017
    2
    Thank you! I think I will go with the XB271HU.
  4. IRobot
    IRobot
    Jun 28, 2006
    1,906
    116
    Leamington Spa
    +1,102
    I've been using the Asus PG279Q for the last 14 months. I think it's the same panel/specs as the Acer. It just depends on which design of the stand/frame you like better.
