Looking for a hollow skirting board to hide wiring
Discussion in 'Home Cinema Building DIY' started by MuffKing, Dec 11, 2004.
  1. MuffKing
    MuffKing
    I've this plastic type made by WireTracks in the USA, but does anyone know of something similar available in the UK so that I can route wires round the skirting board, or should I just buy wooden skirting and put a router to the back of it before fitting?
    [​IMG]
  2. Jamiroquai78
    Jamiroquai78
    you can get it over here, its listed on a few threads in this forum I think its on the MK website, just have a search about :smashin:
  3. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    MK Lincoln looks good
    [​IMG]
  4. TheChump
    TheChump
    That's the one I'm using!
    About £16 for a 3m length and internal/external corners about £2.50 or so each - that's very cheap compared to your B&Q suppliers etc.
    Got mine supplied by local electrical distributors Newey & Eyre.
  5. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    Hey that sounds good, £96 for 6 legnths for a 5.25mx3.5m room + £20 for 8 corner peices then.
    Do you have a pic?
  6. LenScott
    LenScott
    Feb 5, 2001
    102
    Edinburgh
    +6
    Homebase does a new/replacement skirting board that has a channel for cable chasing built in, and is about seven quid a 3 metre length.
  7. doink
    doink
    it only takes a minute to rout the back of any skirting though... then you don't have to resort to cheap looking plastic stuff
  8. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    I guess it's more about having the ability pull off the outer, cover change the cables and clip it back on though.
  9. TheChump
    TheChump
    Still working on the room at the moment - it'll be a little while before it's pic ready.
    It's a lot better than people give 'plastic skirting' credit for - very well made to be honest and better than I thought it could be - it will look very nice when it's finished, believe me.
    As you say, it's the ability to remove the cover and change the cables (or add to them!!!) that makes it a lot easier than ordinary routered skirting board.
  10. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    Looking for something like this right now. A question I have: how would I install this around a bow window (i.e. 5 windows in a semi-circular shape)? I suppose I could just cut lengths at the correct angle with a mitre saw, but they'll never line up perfectly, which is why they do joiners and 90 degree bends.
  11. bobbypunk
    bobbypunk
  12. RemotecUK
    RemotecUK
    Mar 18, 2004
    54
    Birmingham
    Suggest hiring a router and routing out the back - then you can use nice wooden skirting. Thats what I did and it looks really good.
  13. smallangryboy
    smallangryboy
    May 5, 2003
    1,940
    +73
    How about routing a channel out of normal skirting, and using speaker grille plugs attached to the back of the skirting, and speaker grille plug sockets on the wall, to enable you to take the skirting on and off ?
    I think you can get this small marking tool that fits into a pre drilled hole, so that when you press it up against another surface it marks a point perfectly, showing you where to drill so that both holes are aligned. Alternatively you could just use a ruler :)
  14. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    I've got a decent router so could go down the wood route, but was hoping for a ready made solution.
