Looking For A Hd Lcd Tv
Discussion in 'LCD & LED LCD TVs Forum' started by revozero, Dec 21, 2006.
Tags:
  1. revozero
    revozero
    ive been searching for the right tv for well over a month now and i dont want to make a bad mistake, i have £700 MAX and want a 32" or higher hd lcd tv
    my first choice was the SAMSUNG LE32R74BDX
    can anyone help :lease:
    thanks
  2. revozero
    revozero
    anyone?????????
  3. yorkyred
    yorkyred
    Oct 30, 2005
    373
    +39
    Personally the best lcd I have seen is my brother in laws 32inch Sharp. It's not true hi-def althought it does have an HDMI imput. Frankly with tv drive through the HDMI it' looks just as good as any other tv.
    Standard deff is head and shoulders obove anything else I have seen on an LCD. Sorry i'm not sure of the model number although there will be plenty on here who will.
    He paid £699 although I would not be suprised to see that price lowered by now, you may be able to purchase the 37inch for that now.
  4. revozero
    revozero
    can anyone else help please
  5. emrysdavies
    emrysdavies
    Aug 18, 2005
    455
    +14
    You need to give more information e.g. viewing distance and intended use such as games, standard definition or Sky. Then readers will probably suggest the leaders in your particular field.
  6. revozero
    revozero
    it will be used for my xbox 360 and wii with a component cable, and for cable tv
    the only tv's that has grabbed my atention so far are the:
    samsung le32N73bdx
    samsung le32R74bdx
    about 1 to 2 metres viewing distance it will be used at
