looking for a hack for dvd through pc
Discussion in 'Desktop & Laptop Computers Forum' started by janice, Dec 16, 2000.
  1. janice
    janice
    Anyone out there got a hack for a PC DVD player. I want to play both regions but need help????
  2. Cortex
    Cortex
    A problem you have, hmmmm. But not a major one.
    Step One - Find out what type of dvd player you have (My Computer - Properties)
    Step two - Go to http://www.inmatrix.com/files/drvinf_download.html download Drive Info - this will tell you if your DVD drive is protected. If protected go to Step 3. If unprotected for to step 4.
    Step 3 - Protected Drive, go to http://www.firmware.com.bi/ find "firmware" for your drive and download. Look at any text files accompanying the download, they will advise on how to install the firmware, this will hopefully remove the protection "hurdle".
    Step 4 - Unprotected Drive, go to http://www.elby.de/RegionKiller/english/index.htm - download and run DVD Region Killer and there you have it multi-region hassle free viewing.
    Cool or what!!!!!!!!!
  3. janice
    janice
    thanks for your help..... was told to be very wary of downloading from the internet as might not be able to use the DVD drive....is that possible..
  4. Craig Crane
    Craig Crane
    Any decent firmware site worthy of a visit will tell you that you do this at your own risk. Some firmware updates (namely those from the site already mentioned, made by a chap called Noj or something) have proven to be superb. Others are just Drive killers. If in doubt, leave it out. I actually use two drives, one for each region. The toshiba drive is also multi region, via a firmware upgrade. Have a look at http://freespace.virgin.net/woof.bark
    There is a HTPC link at the top of thepage.
    Good luck!
    Check out my HT
  5. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    Alternatively, leave all this worries behind and simply buy an already region free drive from OcUK. You even have a choice of beige or black fascia.
    If you are uncertain of making a DVD region free yourself and want to save money by not having to buy two drives, this is an excellent choice.
  6. Big Jim
    Big Jim
    Any idea what drive you have in your pc?
    to find out go to 'control panel\system\devices' and have a look (for windows 95/8).
    or if you still don't fancy doing anything to your drive - and I had no problems whatsoever - try the following
    http://www.overclockers.co.uk/acatalog/Online_Catalogue_CD_DVD_10.html
    I have ordered from them a few times and they are very good.
    hope that helps
    Jim
