Looking for a good mini hi-fi
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Brit Rocker, May 31, 2005.
  1. Brit Rocker
    Brit Rocker
    Hey all.
    My old mini hi-fi has just given up on me (Sony CMT-CP101, apparently loads of people have had the same problem). I'm looking for a small hi-fi system which will deliver good sound quality for the money.
    My budget is tiny, £100 - £150 (possibly a little higher but I don't want to push it). I've been looking at a Panasonic SCPM31. Anybody know if this is any good?
    Any other suggestions would be appreciated.
    TIA
  2. boomshanks
    boomshanks
    Nov 16, 2004
    47
    York
    Have you read the thread about a small all in one system? It might be slightly over budget, but I can recommend the Teac CRH250 DAB which I bought for a whisker under £200 (exc speakers). I also got a great little set of Mission speakers for £50. Sorry if your budget won't stretch this far, I am sure there are cheaper systems, but none that I have experience of enough to point you in the right direction.
    Good luck.
    B
  3. Brit Rocker
    Brit Rocker
    Yeah, I did have a glance at that before posting but the suggestions were a little too high for me this month. Although I will bear it in mind if I decide to wait a little before buying one.
    I know a lot of you who post on here may only have useful advice on larger budgets, so are there any good (honest/trusted) websites with reviews of the latest equipment?
    Cheers.
  4. Craig
    Craig
    Apr 2, 2004
    305
    Copenhagen
    +4
    Put simply, I'd go for second hand / ebay stuff
    For example, keep your eye on this one...it might go for more than your budget, but it's always worth checking.
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=86806&item=5778820893&rd=1
    (I am in no way connected ot the seller, I just had a quick look to see what was out there)
    Otherwise, the ubiquitous Denon DM30 / DM31 and a pair of mission / tannoy / kef / whatever speakers could be picked up for around your budget
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I've got a now fairly old Sony CMT-CP500MD, I think at the low price bracket the Sony models really are amongst the best available. The build quality, feature count and sound are all good for the price, they also have the benefit of not being too phased by replacement speakers if you ever need to do that or just fancy a change or upgrade. :)
  6. Brit Rocker
    Brit Rocker
    I'd never really thought about buying second hand, so I'll look into that. Even though I don't want to resort to using ebay, I will make sure I look at the freeads etc before making a decision.
    As for the Sony, I've been put off by the fact that my stereo was only 2 years old (almost exactly, coincidence? ;) ) when it decided to give up. I still trust them for more expensive bits of equipment but even then, better things can be picked up for less. Thanks for the input anyway (I don't want to sound ungrateful or anything :) ).
