Looking for a glass 2 shelf stand / shelf
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by hotfuzz, Feb 12, 2009.
  1. hotfuzz
    hotfuzz
    Feb 8, 2009
    5
    I mounted my plasma to the wall thinking I could easily find a suitable low level - sub 40cm 2 shelf glass stand or shelf unit for the dvd/cinema amp and setanta box, this is proving harder to find than I thought. Anyone point me in the right direction??:lease:
  2. da_guru
    da_guru
    Dec 28, 2008
    12
    3
  3. Member 209117
    Member 209117
    I know you are looking for a 2 shelf glass stand but the price of these are so good you may find a use for the extra shelf – Stil Stand STUK1401-CHCL also in black glass STUK1402-CHBL
