Looking for a cable tidy window?
sparklesmcgraw
Does anyone know where I could find a cable tidy window for the hole in the wall I will be making for running cables down my wall when I wall mount my TV?
I'm just looking for something that can fit in the hole I make so everything looks neat.
Anyone have any ideas?
sparklesmcgraw
Yes those are what Im after. But probably ones without the brushes. Just a normal window would suffice.
clockworks
Buy a standard blanking plate and cut/drill a hole in it.
malcolmk
Why not a plate that takes two plug-in network sockets? Very much like one of the brush filled things but no brush. Even my local B&Q sells them and very cheap too - for B&Q.
