looking for a bluetooth headset
Discussion in 'Mobile Phones Forum' started by schillaci0, Aug 1, 2005.
  1. schillaci0
    schillaci0
    Jan 18, 2005
    670
    Starting to get where I want to be
    +14
    :hiya: Looking for a bluetooth headset and have got no idea what's good :thumbsup: and what's not :thumbsdow so i really need some advice :lesson: :lease:
  2. JayCee
    JayCee
    Jan 20, 2004
    22,404
    Lanarkshire
    +2,346
    I have the Nokia HDW-2 (now discontinued) and have just bought a HDW-3.
    It works reliably and audio quality is excellent.
    I bought the HDW-3 off eBay where you can often pick up a brand new unused one for £25-£30. :smashin:
  3. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    You must try them on. Some are very uncomfortable, some people's external auditory meati (the hole going in) are very sensitive to contact. You need to see how quickly and easily you can put it on your ear with one hand. If you wear specs then the clip-on types like logitech interfere with the frame of the specs. The other thing to consider is the microphone, some are noise cancelling and others aren't.
