Looking for a 58" to 65" 4k TV
Discussion in 'What Is The Best TV For You?' started by Vivaki, Apr 16, 2016.
  1. Vivaki
    Vivaki
    Nov 13, 2005
    1,542
    +72
    currently have a 6 year old 58" samsung plasma. Not technically gifted but hoping to get a 4k (HDR if possible, future proofing) TV with a budget of around 1200/1300 pounds.
    Looked at the LG 60uf770v and 60uf850v (no HDR) and they seem like decent TV's but no HDR but good price at around 900/1000
    Samsung ue60ju6800 is the other option I looked at, HDR with firmware update, around 1200
    Panasonic tx-58dx700b is around 1200 and noticed its a new set with HDR
    Which do you think are the best from the list above? Any others to consider in this price range for a 58"+ TV?
    Thanks for the help
  2. Vivaki
    Vivaki
    Nov 13, 2005
    1,542
    +72
    Couple of other options
    Panasonic TX-65CX410B
    And
    Sony 65
    KD65X85 which is a bit more than what I want to spend but is it that much better ?
