Looking for a 5.1 amp
Discussion in 'AV Receivers & Amplifiers' started by FATALGRACE, Sep 12, 2007.
  1. FATALGRACE
    FATALGRACE
    I'm looking for either aa amp with an EQ for each channel (so i can for example: cut the bass on front and rear speakers).
    Or, possibly a piece of software that works in the same way.
    Any ideas?
  2. stringbean
    stringbean
    Oct 4, 2006
    182
    +32
    FATALGRACE you need provide more information on what your budget is, what you will be connecting and what features you need.
    There are currently dozens of 5.1, 6.1 and 7.1 amps that will do what you want - The new Onkyo range starts at £200 for the HTR508 (5.1 sound, basic auto setup plus manual level control) up to the top of the range NR905 for £1200 (7.1 sound, advanced auto setup plus all the bells and whistles).
