Looking for a 20-24" LCD....
Discussion in 'LCD & LED LCD TVs Forum' started by Steve78, Oct 30, 2005.
Tags:
  1. Steve78
    Steve78
    Oct 30, 2005
    14
    Hi all! This is my first post so go easy on me ;)
    I've just purchased a Samsung 32" LCD TV (LE32R41BD) from Waratah (for £840! can't complain at that price!!). This should be delivered Tuesday with a bit of luck. This will be my first LCD unit, but I'm looking to get something for the bedroom (my trusty old Sony 20" WS CRT needs pensioning off).
    I'm a serious gamer and I also love my movies so the screen needs to be more than capable of displaying both to a good standard. As it's for the bedroom the size I need is between 20-24". My knowledge of TV's isn't what it was so I'd appreciate some recommendations. As for the budget - approx £500 (if it's cheaper than this then so much the better!).
    If this is the wrong forum to ask such a question then can a mod accept my apologies and do the hours and move it elsewhere :D
    Edit:
    Just came across this model:
    http://www.webelectricals.co.uk/eStore/Product.asp?ProdUID={19CA4E26-A75D-4049-96D0-BB60C10EF542}
    Looks like my 32" Sammy's little brother!
    Any alternatives?
  2. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +122
    Benq have a new 20" wide panel coming this week, all being well.
    It's a PC monitor primarily, but I believe it can take an S-video signal - so Freeview box is all that's required, or TV card for PC.
    Price - £380 SRP, so that'll probably be nearer £320. 1680x1050 and 4 ms panel, IIRC.
