Looking for 84" or above for meeting room
Discussion in 'What Is The Best TV For You?' started by qwales, Feb 9, 2014.
  1. qwales
    qwales
    May 15, 2008
    270
    Wales
    +15
    Potentially large budget and looking for best option for monitor/tv for board room. It will be used predominantly for presentations from laptops so must have wifi conectivity, which I guess they all will. The only thing I have found so far is the 84" LG & Samsung UN75F8000, any other options you can recommend? P.S. The Panasonic 103" at around £40K is way over budget.
  2. paul1979
    paul1979
    Dec 8, 2005
    8,003
    newcastle
    +1,291
    Get a pj!
  3. George a L
    George a L
    Jan 9, 2005
    483
    43
    Scotland
    +138
    Sharp 90" is what your after.
  4. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,082
    +1,783
    I will stand to be corrected, but I don't think any of the TVs you mention are suitable for your application.
    I do not believe that the wifi will allow connection from a Laptop in terms of sending a presentation. There are various wireless senders you can plug into a laptop and also Apple TV type boxes to allow streaming to a certain extent of screen content.
    As these are domestic TVs, be careful about the warranty, as it may not be valid for business use. That being said, being bolted to a boardroom wall is hardly giving them a hard life!!
    The Sharp TV is very good, but 90" and 1080p means the pixels are actually quite big. For some reason, it is more noticeable than the Panasonic 103", looking worse close to.
    For this sort of budget, you could just about get a 2x2 seamless plasma or LCD. This will give you almost 4K resolution, 84" diagonal and also the ability to show multiple images on the screen at 1 time - depending upon the image processor chosen.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,752
    The Borders
    +3,519
    Wireless 'Video' from a Laptop is usually at a low frame rate so definitely not ideal for anything other than static slides - esp. on a large format display. Wires are still best.
    What is the budget, what are the logistics of getting in such a large display, does the room seating/layout lend itself to a large single display.
    Will you want any form of 'smart' whiteboard/overlay/annotation system for gathering thoughts/ideas etc.?
    Joe
