Looking for 28" to 32" LCD for less than £900!
Discussion in 'LCD & LED LCD TVs' started by christhevan, May 19, 2005.
  1. christhevan
    christhevan
    May 15, 2005
    56
    Hello experts! :hiya:
    I've been looking round the forum, internet and magazines for the past week or so for a new 28" to 32" tv as described :) I've been looking but nothing in particular has stood out, i was wondering if anyone here could help me :)
    I need somthing that is mainly going to be used for my computer and as a TV with a free to air box so no tuner is totally necessary, although i do want somthing HDTV Compatible...
    My computer, has a dual SLI 6600Gt Graphics setup, with a component box boasting HDTV support
    [​IMG]
    I presume i'd need to use this...
    Also i wanted to use a DVD Player, (but if there are some cheaper options without this i can substitute ;) ) hehehe, with the following outputs...
    [​IMG]
    [​IMG]
    and also a Free to Air Terrestrial box, with scart... (i presume the 99% of lcds will have this too :D)
    Any help would be MUCH appreciated...
    Kindest Regards, :clap: :clap: :clap:
    Chris!
  2. christhevan
    christhevan
    May 15, 2005
    56
    oh super... thanks for the help everyone :(
    Chris..
  3. jimg
    jimg
    Jul 4, 2004
    826
    +58
    For Hi-def TV you need a HDMI or DVI-HDCP connection, i.e. a digital comnnection. You CAN have a hi-def analogue feed thru component. Free to air have no plans for Hi-def TV at the moment.
    Does your graphics card not have DVI?
  4. christhevan
    christhevan
    May 15, 2005
    56
    My graphics card does have a DVI yes, i use the VGA for my monitor,
    Only thing is then i'd need to run a DVI cable from one end of the room to the other, and a DVI cable isn't cheap!!
    Thanks for the response!
    Kindest regards,
    Chris
  5. ivor61
    ivor61
    May 4, 2005
    41
    olney
    currys have the samsung lw32a33w in store for £895 in northampton
    i don't know how good they are but it looked ok in the shop.
  6. paulfoley
    paulfoley
    Sep 17, 2003
    3,401
    Hants
    +104
    I was interested in this model last week but discovered in a detailed review just why £400 had been lopped off - Severe smearing problems of the image on all sources.
    :nono:
  7. christhevan
    christhevan
    May 15, 2005
    56
    Thanks for the advice!!
    Chris...
  8. Crivens
    Crivens
  9. paulfoley
    paulfoley
    Sep 17, 2003
    3,401
    Hants
    +104
    Why not look at the new 26" & 32" samsungs at Empire Direct? Great spec, amazing price but probably a long wait as so many of us have pre-ordered now (See seperate thread). Good luck!
    :smashin:
  10. greig
    greig
    Jun 13, 2005
    84
    +6
  11. Crivens
    Crivens
    It asks for a discount code before you order it apparently. I assume it then lowers the price. The email just said to use "TOSHIBA-UK" as the discount code when you place the order.
  12. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    I think i've read somewhere in the toshiba thread that the offer has expired,
    although i can't find it now, sorry
  13. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    Found it LINK
  14. greig
    greig
    Jun 13, 2005
    84
    +6
    Yes, oh well, thanks both!
