Looking for < 23inch LCD/LED TV with Freeview HD Tuner inbuilt
Discussion in 'What Is The Best TV For You?' started by JamsDM, Jan 9, 2012.
  1. JamsDM
    JamsDM
    Jan 9, 2012
    3
    Hello
    I have 2 old CRT Portables with analogue tuners to replace due to Digital switch over in 6months time.
    I am looking to replace with either 19/22inch LCD/LED screens but would like the TV's to be able to tune into Freeview HD Channels which will be available on my transmitter in 6months time. I do not want to have a separate tuner box just for the HD Channels.
    Are there any small (19 / 22inch) LCD/LEDs which have Freeview HD Tuners built in or is anyone aware of any planned for release soon?
    Many thanks
  2. mikej
    mikej
    Aug 1, 2005
    931
    43
    +97
    What's your viewing distance ?
    You're only going to benefit from Freeview HD (in terms of picture resolution at least) if you're sat a few feet away from a screen that size.
    When I bought a couple of smaller (19" and 22") LCDs for other rooms in the house a year or two ago, none came with Freeview HD tuners - presumably for that reason. Not sure if this has changed recently, though ?
    AFAIK, all the content currently broadcast on the Freeview HD channels is also shown in SD, either simultaneously or at other times, so you're not missing out on content if you can't get HD.
  3. JamsDM
    JamsDM
    Jan 9, 2012
    3
    Mike - viewing distance will be quite close 4-6 feet.
    There's plenty of affordable HD Ready/Full HD small screens about, just none seem to have Freeview HD Tuner inside.
  4. xeny
    xeny
    Jan 10, 2012
    JamsDM, I doubt anyone will rush to release a FreeviewHD capable small screen TV.
    There's no advantage to discernible picture quality to have HD on such a small screen, and the selling price will be lower for a smaller set compared to a larger one, so it's an added cost that manufacturers will like to avoid if possible.
    If you don't want to buy TVs without Freeview HD, and your existing TVs don't have SCART sockets for an ordinary freeview box, you could look for freeview boxes with RF outputs that plug in to an existing TV aerial socket.
  5. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  6. mike7
    mike7
    Jan 3, 2005
    4,938
    Norwich
    +615
    There is a Panasonic HD ready version of this Panasonic for £219 from Richer Sounds.
    Panasonic VIERA TXL24C3 | 24 inch LCD TV HD Ready Freeview HD | Richer Sounds
    I demo'd this alongside the Full HD one and couldn't really tell the difference. It makes a great little set for bedroom use and I've been very pleased with it. Sounds good too as it is not an ultra-thin LED backlit model.
  7. JamsDM
    JamsDM
    Jan 9, 2012
    3
    Vicster - thanks, there's also a 19" version of the http://www.hiwayhifi.com/site/produc...469&Prod=33507 available on Amazon - with nice enough reviews.
    Mike7 - thanks another great possibility.
    Would ideally like a 22" though for my Kitchen, anyone have any other suggestions?
