looking fo a "narrow" hifi rack
Discussion in 'Hi-Fi Stereo Systems & Separates' started by mick23, Jan 4, 2003.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    i have been looking for a hifi rack that is just wide enough to take standard size kit amp cd etc, but all racks i have seen are much wider, i want to have adjustable shelves etc but due to width of room a narrow rack would be ideal, does such a rack exist and links to please,thank you
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,083
    +343
    Mick best "Narrow" rack design Ive seen is from Ash Design, check out the link below, the "Cosmic Tower" is probably your best bet for Narrow, I own a Cosmic 4 and it is very pleasing on the eye.
    www.ashdesign.com
    Hers is the full range :
    http://www.ashdesign.com/cosmic.php3
    HTHs
  3. mick23
    mick23
    Mar 20, 2002
    801
    uk
    thanks cj nice looking rack but still 600mm wide, i did recall a narrow rack in local 7 oaks,but not sure of make, could do with something nearer 500mm if possible thank you
  4. CJROSS
    CJROSS
    Nov 16, 2000
    5,083
    +343
    Mick greetings duder, here is the width of the Cosmic Midi Rack, which seems right up your street (480mm)
    Cosmic Midi Clasic 5 :
    Size: (HxWxD) 635 x 480 x 450mm
    Glass size: (WxDxH) 480 x 400 x 10mm
    A 500mm component will fit in that shelf size as their is 15mm clearance each side for shelf pegs. These racks are also user adjustable in shelh height as well. Ring up Ash with your components sizes.
    HTHs
