Look at these specs
umgee
Manufacturer: LG
EAN: 8801031067411
Brightness in Candela/m²: 500
Common Interface Slot: Yes
Contrast Ratio (X:1): 5000
Depth in cm: 8.5
DVB-C: No
DVB-S: No
DVB-T: with Digital Tuner
DVD Player / Recorder: No
DVI Interface: No
Electronic Program Guide (EPG): Yes
Energy Savings Trust Feature: Yes
Frequency: 50 Hertz
Front AV Interface: Yes
Full HD: without Full HD (1080p)
Hard Disk Capacity in GB: -2 GB
HD ready: HD Ready
HDMI Interface: with HDMI
Headphone Output: No
Weight in kg: 9
Height in cm: 47.7 cm
Horizontal Resolution in Pixel: 1366
Loudspeakers: with Loudspeakers
Memory Stick: No
Number of HDMI Inputs: 3
Number of Scart Interfaces: 2
PC Interface: Yes
Power Consumption in Watts: 130
Power Consumption Standby in Watts: 0.9
Reflection Angle: 160 degree(s)
Response Time in ms: 8
RMS Wattage: 10
S-Video Interface: Yes
Screen Format: 16:9
Screen Size in cm: 66 cm
Screen Size in Inches: 26 in
Secure Digital Card: No
Type of Monitor: LCD
USB: No
Vertical Resolution in Pixel: 768
Width in cm: 67.2
YUV Interface: Yes
Do you think this is good enough for action movies, sports and PS3 games without blur?
audiphile76
Avoid LG.
What is your viewing distance?
Get a Sony instead. You could consider a non 1080p panel if your viewing distance is more than 8 feet.
umgee
Avoid LG.
About a metre, a metre and a half away.
Why avoid LG? I thought they were good?
This is my first hdtv but i've been researching a lot over the past week.
This one I can get for around £270.
Someone recommened a Sony 32V4000 but at £370, that's over £100 over my budget.
audiphile76
LGs i have heard have issues, same goes with Samsung too. Sony on the other hand especially 32V4000 is supposed to be the best in its category for good blacks, good processing and reliability.
ChrisGgr
I fully agree with audiphile
umgee
Thank you for your advice, now I will have to spend my food money or take a loan for the extra 100 to buy the Sony. lol:suicide:
Can I ask you another question please?
With the Sony TV, could I connect it to my laptop and use it to play Mugen? (Mugen is a mod emulator which allows you to play the 2d streetfighter games and such on your PC)
ChrisGgr
you can connect your laptop for sure
Samsung & LG UK TV Prices 2023; Amazon Fire TV Cube; Calibration Tools of the Trade + AV news
