longer xbox extension cables req'd?
Discussion in 'Xbox Forums' started by Pantastic, Sep 24, 2004.
  1. Pantastic
    Pantastic
    I currently have my xbox in a cupboard under the stairs and I use the wireless controllers available from GAME. But here's my dilemma, I want to get hooked-up to xbox live without moving my xbox, but I will have to replace the wireless controllers with the official ones I got with the xbox and then I need to run the cables from the xbox to the front room (well over 2 metres).
    Is there a longer extension cable available for the xbox controller?
  2. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    yes there are extensio cables available you can find them on sittes such as ebay etc
    as well as your normal high st stores
  3. Pantastic
    Pantastic
    Yes, but they're the 2 metre ones - which are too short.
    What I need is a longer one... :blush:
