I have a Panny PWD8 panel that was supplied with a power supply cable that is approx 2 metres long. I need to find a replacement cable that is 3 metres long.
Can anyone tell me where I might find (buy) a replacement power supply cable that is 3m long?
I've taken a look at the sticky for DIY cables but I can't make head or tail of anything being discussed there. I have no idea if a straight forward 3 metre lead and kettle style plug would do the job or if I need something that is shielded. I'm not looking to improve on the specification of the cable that was supplied, I just want to replace it with a similar one that is longer.
I will be burying it in the wall as the screen is wall mounted.
Thanks in advance
Phil
Thanks in advance
Phil
