Longer Cable
Discussion in 'Cables & Switches' started by Rasczak, Jun 1, 2002.
  1. Rasczak
    Rasczak
    Apr 3, 2002
    21,859
    Warwick
    +2,781
    I am thinking of purchasing a new larger TV but, given the limitations of my room, means I will have to move all the other gear (VCR/DVD etc) to one side which would require a 5m cable run between them and the TV. Clearly I'm worried this will significantly reduce the quality of the image - does anyone have long cable runs and able to offer advice? In particular what make of cable do you use?
  2. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    I am using a 10 Meter stretch of component, composite and S-VHS cables, with no problems. These are Van Damme.
    If you are looking at a scart lead then you should have no problems as long it is a very good quality one with plenty of shielding. Not sure who make these though. (QED might) If the signals will only be going one way it ill be worth getting a omni directional cable and not a bidirectional one, which most are. I.e. only one set of pins is wired up. This is to avoid cross talk.
