Long throw lense available for Infocus Screenplay 7200?
Discussion in 'Projectors, Screens & Video Processors' started by Mark Pitchford, Jul 16, 2004.
  1. Mark Pitchford
    Mark Pitchford
    Mar 9, 2001
    209
    Scotland
    +4
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Very few home cinema projectors have the option of interchangeable lenses.
    I'm pretty sure the 7200 isn't one of them.
  3. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Have you measured up Mark?
    The Infocus/MT8 has a throw of 1.49 to 2.08:1 (distance to width). i.e. for example I have a 2m wide image with the projector 4m away from the screen.
    Do you have a langer than average room or are you looking at projecting a smaller image?
    Ian Guinan
  4. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    p.s. check out the specs at www.infocushome.com
    It has a superb throw calculator which lets you set any variable and experiment with throw distances etc.
    There is no optional lens for the 7200.
    I think the ones I've heard of with long throw options are;
    Marantz
    Sharp
    Sim2
    but they can be very pricey and sometimes not that much more 'long' throw.
    Ian Guinan
  5. Mark Pitchford
    Mark Pitchford
    Mar 9, 2001
    209
    Scotland
    +4
    Thanks Ian,
    I've checked the links you've provided.
    The room's 6.5m long with an entertainment unit at one end with the TV etc. in. So I'm looking at a throw of about 5m from the back wall of the room which would give me a screen about 2.4m wide.
    This sounds great until I realised that a screen that width would cover my speakers that are housed within the shelves of the entertainment unit.
    I was hoping to put the projector on the back wall out of the way. It looks like I'm going to have to move it forward a little into the room so it'll be a little more conspicuous.
    Thanks,
    Mark
    PS I've made an offer on Postie's projector and am waiting for a reply...
