Long throw LCD needed
Discussion in 'Projectors, Screens & Video Processors' started by WoodyAllen, Jan 19, 2004.
  1. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    I was on the verge of purchasing a Z2 (after several weeks of reading this most excellent forum..) when I discovered that the throw was too short for my room (thanks to an owners manual download from a previous post).
    I'll be wall mounting the PJ about 6 metres from the screen (white wall initially) and image width is 'limited' to around 3 metres.
    Can anyone recommend a LCD with a suitable range? Budget is around 2k.
  2. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    Sony HS20 fits the bill. Try a search on this forum.
  3. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    I just downloaded the owners manual (via http://www.iq.sony.com/srvs/sosdocs/default.asp) & it looks like it fits the bill nicely. Cheapest price I could find is £2,095.95.
    Before I buy, any others worthy of consideration?
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    the older HS10 is still a good machine...... you can get it for alot less than the hs20 which would allow you money for other important accessories.
    ad
  5. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    Cheers buns,
    a quick search could only locate the hs10 for £2069.00 (same as hs20). Have you seen it cheaper anywhere? All savings welcome as I need a new dvd player as well.
    Would the ae500 cope with a 6 meter throw?
  6. spacekdet69
    spacekdet69
    hi all!!!
    try reading (vicbarrys--TYPICAL) thread, if memory serves me right think the hs10 gets a mention there.....around the £1200 mark i believe and in stock, havent had the time to check the website myself yet...... hope that helps..
    all the best
    regards
    nick.
  7. WoodyAllen
    WoodyAllen
    Jan 19, 2004
    91
    Northern Ireland
    +4
    good memory Nick, cheers.
    The HS10's are described as "graded" on the web-site; I've e-mailed them to enquire what this means.....
    Best
  8. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    the graded ones were what i was referring...... as far as i can gather this means they are almost new but perhaps factory returns that have been fixed or something.
    ad
  9. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,807
    Hogsty End
    +70
    I spoke to robert Whyte yesterday. See my last post in this thread .
  10. MrSafety
    MrSafety
    See "TYPICAL" thread. HS10 available for £1850.
