Long Shot - Win98 and WMP9 ?
Discussion in 'Desktop & Laptop Computers Forum' started by deaf cat, May 9, 2005.
  1. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    Hiya,
    Simple question really, would wmp9 work on win98 ?
    If you are thinking it may be a bit tricky what do you thing may be the newest wmp that would work on 98. Its just that I am used to using wmp9 and it would be nice to transpose play lists etc.
    Look forward to any positive......... comments......
  2. MikeFish
    MikeFish
    According to the Windows website there are 2 downloads available for WMP9. One is for Windows XP, the other is for Windows98SE/ ME/ 2000.
    Click here for download.
    WMP10 might even work. Can't see any system requirements mentioned for 10, but it does keep referring to XP.
  3. sy278
    sy278
    Jul 4, 2004
    510
    28
    Glasgow
    +40
    not sure about Win98 but it does work on WinME, and there isnt a great difference in them, so I suspect it will work, but if I remember it has a specific download for no XP platforms.
  4. sy278
    sy278
    Jul 4, 2004
    510
    28
    Glasgow
    +40
    Mike just got in there first.
  5. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    Wonderful news, I'll give it a bash
    Cheers 2 you both !
    Thanks for the short cut.
