Long Scart or co-ax?
Discussion in 'Cables & Switches' started by Slimchandi, Feb 23, 2005.
  1. Slimchandi
    Slimchandi
    Dec 23, 2004
    486
    +3
    I am about to reposition the av set up in my front room, and place my Freeview receiver about 4 metres further from the aerial point than it was before. Obviously there is simply not enough cable to reach that length. So I have two choices; either
    1) Add a length of matched co-ax cable (CT100) and maybe a small signal amp near the source to make sure there is no loss, or
    2)Plug the Freeview receiver in on the opposite end of the room and run a long Scart cable to my Pio amp!
    Would one method be preferable to the other? I suppose the co-ax method would look a bit nicer (and cheaper) than the Scart, but could lead to more loss.
    Any tips would be frustratingly received!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    extend the RF run to box mate just make sure you use quality cables
