Needing a longer power cord for my PT-AE300 (I need 8 m). Anyone know if those can be found? I would be content with just getting the kind of adapter that goes into the projector end (the one with three holes in it), but event those are extremely hard to get over here (in Sweden). I don't know if it's some UK standard, or a projector standard but they seem unavailable here. Johan
If you can find any identification numbers on it, post them here and we may find something for you. You can try looking over at www.cpc.co.uk and see if you can find something there. Gary.
my AE100 came with two power cables - a three pin and a Euro two pin. i chopped the end off the two pin and wired it to the end of a normal extension cable.
