Long leads?
Discussion in 'Projectors, Screens & Video Processors' started by jGrahamD, Jun 5, 2003.
  1. jGrahamD
    jGrahamD
    Feb 11, 2002
    260
    I'm thinking of getting a projector, but because of the room layout, would require a video lead in excess of 5m. Does anyone know what the best way of doing this is?
  2. juboy
    juboy
    Hi there. Not sure if you need component cables or not but I just bought some custom length ones from Scorpion Cables and they perform far better than the Supra AV3 cable I used previously (which in itself is a cracking cable).
    The best thing about Scorpion Cables is that they use true 75ohm connectors and the best quality cable out there plus they'll make it to your specific requirements.
    Might be worth contacting them via www.scorpioncables.com
