long interconnection pre amp to power amp
mr magnolia
I am pondering adding power amp (audiolab 8300xp) to my audiolab 6000A, but for the next little while - say about 3 yrs maybe :) - I would need to house the power amp a distance away from the other units. Distance would be approx 4m from amp to power amp.
I already have in use unnecessarily long 5m long speaker cables from previous other dwelling set up from 15yrs ago; so no change to those cables needed.
in the current set up, my only shelf space where pre amp could logically and visually acceptably go is 150mm between non adjustable surfaces and 8300xp is 149mm high so that's not clever.
would 4m long RCA interconnects and trigger cables between amp and pre amp make a noticeable sonic difference?
thanks
Donald
3rdignis
I use 2m xlr, 25cm speaker cables and monoblocks.
8300xp/mb have xlr and rca.
Cable losses are the thin end of the wedge.
Upvote 0
Timmy C
I think my cables are about 3m between pre and power and I asked the same question when setting mine up. The replies on here at the time were good enough to stop me worrying and I can't say I've noticed any difference since setting it up that way.
Upvote 0
mr magnolia
thanks guys. I've failed to get domestic approval for my plan in any event so will have to go for something with a smaller bulk, but its good to know for the future plans!
Donald
Upvote 0
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
