Long HDMI cable (~10m) any suggestions?
Discussion in 'Cables & Switches' started by Chairmanron, Jan 16, 2008.
  1. Chairmanron
    Chairmanron
    Jan 13, 2008
    175
    I think I need a replacement 10m HDMI cable, as I suspect mine (only a cheap one) is at fault.
    Are there any ones that people would recommend which are not too expensive but still give good performance over this sort of length?
    Ideally I would be after an HDMI to DVI cable but I could always get a converter.
    Many thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    speak to JoeF of the media factory as he can test cables to 1080p and sell you one that will work as either HDMI to DVi or with a converter
