Long digitalcoax or svideo
Discussion in 'Cables & Switches' started by BruBoy, Mar 25, 2005.
  1. BruBoy
    BruBoy
    Basically, I have a choice between having my DVD player next to my TV or next to amp.
    There is a distance of ~5m between them. At the moment, I'm using a long svideo cable to cover the gap but would I be better off using a long coax cable to carry the digital audio and having a short video connection to the TV?
    TIA
    BB
  2. chrisstu
    chrisstu
    Feb 24, 2005
    50
    Probably not worth worrying about if you're using svideo.
