Logitech Z-5500 - Connecting to a TV?
damanc
Hi Guys,
After recently moving house I have decided the home entertainment needs an overhaul.
Before I had a media center PC which contained a TV Tuner, decent Creative XFI sound card connected up to a set of Logitech Z-5500 Speakers (Support + Downloads: Z 5500 Digital 5 1 Speaker System - Logitech) and a HDMI cable to a 42" LCD Screen. All worked quite well if i'm honest.
Here is the twist - My new place is in a cabled area and we now have Virgin Media TV service complete with a TiVo box.
I want my new system to comprise of a new TV, the TiVo box for VM Services, A media center (Just for playing films and the TV tuner becomes redundant) and of course keep my current Z-5500 setup.
Now, bear with me as i'm no AV guru - Previously, my speakers were rigged up simply to the audio ports on the PC. Now I have two devices I would like to use to output sound both the TiVo Box and Media Center. Swiching wires over each time I fire up the media center is something I would really like to avoid.
Logic inside me says that I can connect both the media center and TiVo box via HDMI to the new (un purchased) TV and then connect the Z-5500 system to the TV Somehow. Does that seem right?
If so, what connection do I need to look out for when buying a new TV? Connectivity of the Z-5500 can be found here: http://www.logitech.com/repository/1411/pdf/13098.1.0.pdf
Any advice greatly received. :)
PSM1
Does the Z5500 have an optical input? If so use this for virgin and the multichannel inputs for the media centre.
A lot of TVs will not pass sound from HDMI inputs to any of the sound outputs and if they do most of those only pass a stereo signal hence would not give you surround sound. Hence connecting everything to the TV and then TV to speakers will most likely not work well.
andy1249
The Z5500's have two digital connections , and the six analog connections for PC can be split to 3 x stereo.
If any of your devices have a co-ax digital out , use that connection, if not , then optical to co-ax converters are cheap and quite common.
Any audio input on the TV's HDMI is usually not sent to any of the other audio outputs on the TV. Those outputs are for the TV tuner or services only.
The only way HDMI inputs on the TV output audio is via ARC , and both TV and connected Device must support that feature for it to work. Obviously , that is not possible with the Z5500's.
BobBob21
The most obvious answer is as PSM1 says, assuming you connect the PC using 6 analogue then I am sure the TiVo box has an optical cable and bobs your uncle. When you change source just need to select the correct source on the logitec thing
Not that common for TVs to have decent sound Outputs connections as ARC would be out of the question but as you dont say what your TV model is we cannot check for you.
Icemen
Hi peeps. Quick question. Cant see it has been answered here. How do you connect logitech z5500 to a tv direct ? Is via optical cable? Or is some sort of adapter required also?
Bronze458
Optical cable from TV to the speakers control unit.
You need to make sure your TV is outputting Dolby or DTS and it should work fine.
If I remember it can only decode those formats
Icemen
Came with a really thin optical cable connected to tv didnt work to well. Surround speakers where alright but sub not much sound. I think i need to buy a thick quality optical cable. Tried it on the pc sound card with the three green black orange cables and it rockz.
Icemen
Also will system work better with coaxial cable or optical cable?
It only has one port for coax cable but tv has two? Red and black?
Bronze458
To get 5.1 using your TV you'll probably have to use the optical port as that will send Dolby digital or DTS 5.1 to your Logitechs amp.
The red and white connection on a TV are usually just analogue stereo output so I wouldn't use that. As it'll just be stereo only, though it can be upscaled to 5.1 by Dolby Pro logic which the amp has.
The coax on the Logitech is for digital coax which is a different format.
It may have sounded better on your PC due to your PCs sound card being able to output a better quality signal. Analogue not a compressed format like Dolby 5.1
Might be worth using optical and tweaking your sub levels on the amp control unit
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
