Quantcast
Logitech Wireless Speaker Adapter for Bluetooth® audio devices
DECKARD71
Hi all
I have searched the forum with no results, so I am asking: Has anybody tried this new device?
Logitech Wireless Speaker Adaptor for Bluetooth Audio Devices: Amazon.co.uk: Computers & Accessories
I currently use an Apple TV to stream music from my iphone and ipad to the AV receiver. I am more than happy, however it resamples music to 48khz, and when I stream music from my iphone to the AV directly (I can also do that, with no Apple TV in the middle) I notice a better quality, as it keeps 44.1khz
You might wonder why I do not always use the second method (from iphone to AV directly). It is just because it does not accept m4a format (apple lossless) so I can use it only for mp3
So, if anybody has tried it, please share your view on it. I have made hundreds of searchs in internet and still do not know which sample it delivers, 44.1 khz or 48 khz. For the price it deserves a try
larkone
Bluetooth has limited bandwidth (768kbits/s) and this is further limited to 512kbits/s for stereo so you will struggle to get hi-quality sound this way. You need a BT device that supports apt-X to get hi quality sound sound over BT
I am right in understanding what you are saying with your setup - that a lossy codec mp3 at 44.1kHz is better quality through your stereo than apple lossless at 48kHz when streamed by an Apple TV?
DECKARD71
Hi Iarkone
Thanks for the reply
TBH I do not know how bandwith affects quality, I understood that if bandwith is enough to transport data, then is ok. Is 512kbps not enough for music?
Indeed I get better quality from a mp3 at 44.1khz (especially 320k mp3) directly from the iphone to the AV, than from a m4a (lossless) at 48khz from Apple tv.
In fact there is not much difference between mp3 and m4a when streamed both via Apple TV at 48khz
Regards
larkone
Lossless bit rates will be around 800-1411kbps so the ad2p protocol on BT will not give you the improvement you are looking for. You would probably be better of getting an Airport Express which keeps your stream at 16/44.1 and use the optical out and let your receiver decode the stream - you don't say what receiver you have but am assuming you have a spare optical input.
DECKARD71
Ok but which is the bandwith needed for mp3, just for curiosity. I have a very capable AV yamaha rx-v2067 so of course it has optical inputs. In fact I was about to buy the Airport Express, but at that time the Apple TV was just released, at not much higher price, so I went for it, not only thinking about streaming music but also videos and movies, pictures, and the cool feature of seeing the album cover art in the tv, etc
Now my hearing wants more, so unless Apple TV fixes the 48khz issue, I will go for other streaming device, not yet sure if Airport Express or another one with 1080p streaming capabilities
larkone
Mp3 bitrate depends on what quality setting you have. Have looked at the specs for your receiver and it does support mpeg4 - Page 145 of your manual. Why not connect your receiver by ethernet and stream music that way from your PC or Mac and take the Apple TV out of the audio equation. It supports cover art as well. If your receiver is not recognising m4a files then try changing the extension to mp4.
If you really want to go with the best quality then step out of Apples walled garden, rip your music to flac and use one of the many free s/w products to stream to your receiver and remote control it with your i-things.
DECKARD71
Yes, the issue is that both my PC and AV are DLNA. This sounds good, but the truth is that 70% of the times the AV does not see the PC, and in addition DLNA protocol does not support lossless audio streaming
I will keep searching, your advice of using AV&PC is the best option of course, however I have those 2 issues: connection and lossless
Thanks and Merry Christmas!
larkone
According to the manual it does support flac and other lossless formats over dlna
DLNA
Version 1.5 (DMP & DMR support)
Audio Format MP3,WMA,WAV,MPEG-4 AAC,FLAC
Max Audio Support fs 96kHz/24bit
Cover Art Format PNG,JPG
I would hazard a guess that the issue of network connectivity will have more to do with either your router or PC setup (including firewall or anti-virus)
DECKARD71
Yes that is the theory, but DLNA and lossless are not friends at all
DECKARD71
Well, I connected the AV directly to the ethernet connection of my living room (previously it was to a switch) and now I can see the Asset upnp server
It is wonderful, I can stream now m4a, dts, flac, etc. Great sound and nice navigation from iphone (though not as good as from Apple tv, but what matters is sound), so very happy with Asset upnp
Next step is to make it work connecting the AV via Switch, as I need a Switch to share the ethernet connection with the Apple tv (which I will use less from now on as I dont like the 48khz resampling), the PS3 and the MediaCenter HDD
So.... I am not trying the topic of this thread, logitech wireless adapter
larkone
Glad you got it sorted - it sounded like a network issue. If you want to re-introduce a switch then look into whether your router has QoS settings so you can prioritise media files
DECKARD71
Thanks Iarkone. I am changing to a n-router today, so I will look at that
Similar threads
